What changes were made for the MK2?
The Fremer review in Stereophile outlines the changes and a whole lot more. I’ve listened to these speakers at Axpona the last two years and their sound quality and soundstaging are truly world class.
Ken [...]
Borrowed another pair. Belt and suspenders!
So you need 4-channels of amplification to drive the speakers?
Mike,
For each speaker, are you using a “Y” cable to split the signal from the single cable coming from the preamp to the two amps? Or are you using some kind of external crossover?
Thank you Mike. What I meant to ask was about the interconnect from the preamp to the amp. Are you using a Y interconnect cable to split the signal and connect to the two mono amps?
I assume you’re asking about the four monos? I’m using and XLR connector between the amps. The MBL amps are designed to be daisy chained.
Are you in Fl Jim?
