New speakers for the new store.
Can't wait to set these up.
Looking forward to your impressions. Active and adjustable bass would enable it to fit most rooms. Unlike AvantGarde though, RV does not believe in digital EQ or amps.
Supposedly great synergy with Ayre so Ayre QX-5 Twenty + AX-5 Twenty with the Quatro CT would make a great system.
That's the idea! All AudioQuest power and cables too. Vandy/Ayre/AQ will be a great combo to show. I'll sneak an Aurender or Lumin U1 in there too to play with the Ayre QX5. [emoji6]
While there, you might also want to sneak in a Melco to take advantage of the ethernet input on the QX-5. Ayre uses the Melco.
Mike I can't wait to hear the Quatro CT , it peaks my interest
I've received a LOT of interest about the Quattro CT's. When I get them set up, you have to come over to the store for a listen. I'm waiting on my AQ cables for that system. Source will be Aurender A10 (just using the USB output) into the Ayre QX5 DAC.
JOE! ?????
You'll have to sell your JBL's
