Very interesting with Alnico magnet. Any one have a chance to hear them ?
Tannoy Definition DC10A
Specifications
PERFORMANCE
Recommended amplifier power
(Watts RMS) 30 – 300
Continuous power handling
(Watts RMS) 150
Peak power handling (Watts) 600
Sensitivity (2.83 Volts @ 1m) 93 dB
Nominal Impedance (Ohms) 8
Frequency response (-6 dB) 28 Hz – 22 kHz
Dispersion (degrees conical) 90
DRIVE UNITS
Dual Concentric™ high frequency 51 mm (2”) Aluminium alloy dome. Alnico magnet system with Pepperpot Waveguide™
Dual Concentric™ low frequency 250 mm (10”) treated paper pulp cone with twin roll impregnated fabric surround.
52 mm (2”) edge wound voice coil, Alnico magnet system
CROSSOVER
Crossover frequency 1.1 kHz
Crossover type Bi-wired, hard wired passive low loss 2nd order LF, 2nd order compensated HF, Cryogenically treated
CABINET
Enclosure Type Twin Rear ported
Volume 103 L (3.64 cu. ft.)
Dimensions (H x W x D)
inc plinth & grille 1135 x 345 x 438 mm
(44.69 x 13.58 x 17.24”)
Weight 42.7 kg (94.1 lbs)
Finish High gloss black
High gloss cherry
High gloss dark walnut
