NorthStar
Good timing ...
Received my A8F. Spectacular. Worth the extra $$$.
Thanks Dan. That's very interesting. What's your thoughts on the Z9D 75 inch?
Mike, are you a 3D fan? For me personally that's the biggest difference.
The Z9D is another top choice.
Then we don't have anything to talk about.![]()
Mike.......I have not viewed a Sony Z9D 75" television, but everything I have read about it says it is one of the best LED LCD TV's on the market. It uses Sony's 4K HRD X1 Extreme processor, as well as their Backlight Master Drive, said to produce unprecedented dynamic range with incredibly deep black levels. The ZD9 series has Sony's ultra dense LED structure featuring local dimming that aids in the amazing contrast between light and dark. Each LED is discretely controlled which helps create an extremely accurate picture.
A couple of reoccurring comments I've read say that the ZD9 series suffers slightly from issues with motion, although Sony's True Cinema motion setting dramatically improves this issue, and picture quality deteriorates when viewed at angles exceeding 35 degrees or so. This is not unusual for LCD screens. The importance of these issues would have to be determined by you as to their impact on your viewing requirements, but most likely minimal.
Perhaps someone with a Sony ZD9 series televisions can chime in. The ZD9 series is getting rave reviews.
The motion blurring would drive me nuts. I pretty much only watch hockey.
Then your choice is easy:
Sports: 8.7
Excellent for sports fans. Motion handling is excellent due to the instantaneous response time and ability to flicker the image to clear up motion. Dirty screen effect is also not an issue, as the screen is very uniform. Picture quality is also excellent, and remains accurate when viewed at an angle which is great for large numbers of people to watch an important game.
[emoji830] https://www.rtings.com/tv/reviews/lg/c8
Mike, I've never owned all those TVs in the same room ... that would require a huge dealer room, which I am not. Rtings is a good resourceful site in helping people like us to make the right choice.
You're a hockey fan, and if I was (I used to be, big time), I would buy the new LG OLED, 8 Series, 77" because you like the big size, and me too.
