This may have been mentioned elsewhere, but whatever 6650/KT88 power tube you like in your ARC Reference power supplies, you may not be hearing what they sound like if you're not using tube dampers on them. As I've improved my system setup, I began to notice a very slight haze/dryness using the SED Winged "C"s. It made me wonder too about my REF10 phono where I switched to Shuguang Treasure Zs.
For the last week, I've been using Herbie's Audio Lab high-temperature HAL-O IIIs on these tubes and really noticed a significant improvement in clarity and detail without any downsides of a more analytic presentation. They are made with titanium, not PTFE/Teflon or Sorbothane. Note, these tubes reach temperatures of 450 F so I wouldn't cheap-out with dampers of some other material, although PTFE ones will work.
I liked them enough, I'll be experimenting with the smaller size on the 6H30s instead of the ARC supplied dampers.
Note that Herbie's recommends the "50s size" for bulb-shaped KT88s, but that only allows them to be placed at the very top of the tube, not the middle. That seems to be just fine though. Have fun!
