Mark Jones
The Roger's marketing seems a bit over the top for me, plus how do they get 112 watts in class A out of two KT150's, probably cause it's not class A!
5) Your Diapason speakers are rated at 91dB sensitivity @ 1w/1m and has a nominal impedance of 6 ohms, which suggests on the surface that they should work fine with a tube amp but there is a drop in the impedance curve to 3.4 ohms at 200Hz (upper range of midbass frequencies) so you would still want to have a capable amp with sufficient current delivery via the 4ohm taps to make sure there is not a hesitancy or a diminution at 200Hz where a lot of what we hear as bass information is really midbass info. To see what instruments lie in this region, refer to the chart below:
6) One final option to consider is a hybrid integrated amp, with tubes placed in the preamp stage or the input stages of the power amp and a SS output stage, which should give you some tube flavoring without the hassles of dealing with changing out output tubes every few thousand hours and biasing them etc...One option that comes to mind that I think is an excellent hybrid integrated amp that is also from Italy (like your Diapasons) and that is visually very striking (some people love it and others not so much) is the Pathos Logos (now in mk II version). I have heard the Mk I version which a friend used to own with his Focal speakers and it was a match made in heaven. Here's a pic of the Pathos Logos in case you are interested (but remember there are many such designs including an option that has been talked about here a lot, the Musical Fidelity Nuvista 800 integrates amp):
Pathos Logos:
The Pathos has been on my short list for a while as well as the speakers recently. Gorgeous together!
I am planning to add a Rogue Audio Cronus Magnum tube integrated to my collection. I know that it has an excellent reputation for superb value at $2300. Do any of you have anything critical to say about the amp or its limitations? If I were to spend twice as much (say $5,000), is there a brand or model that would offer substantially greater performance and still offer excellent value? If so, please elaborate. THanks!
So I have come full circle in my search for a suitable tube amp to bring into my system. I've ordered the Rogue Stereo 100. Everyone experienced who I trust continues to praise the Rogue products. The 100 is more refined than the Cronus, and has a better fit and finish. I will likely add the new Rogue RP-5 preamp soon. My dealer (a shark) wants to give it a close listen before he endorses it. So initially I'll control it with a Blue Circle 21.1 tube line-stage.
Mike, how do we get a Rogue Audio manufacturer forum added to Audio Shark?
Get five others to agree. I like Rogue gear too, but the manufacturer list can get out of control real fast.
