Toobs are still around because Audio has nothing to do with good sound it has and always will be about what one likes, one man’s Audio Euphoria is and will always be another's anathema, So there’s good sound available from Toobs , SS , digital and or analog and i have never owned or used a bright or Harsh SS amp in 40 plus yrs, its an old straw man argument very similar to what pro SS people do when they say Toobs are dark and slow ...
So while some toobs maybe dark and slow and some SS harsh and bright these are characteristics of poor design choices ..
That aside ,
you will have to prove That brightness between SS amplifiers were not from non clipping or running out of class A bias for the load , we have done that rodeo too many ( Bob Cordell even went as far as to do a show setup to prove this by showing how much power was necessary to prevent clipping from only 1-2 watt rms use ) times and a non clipping properly biased for the load SS amp will never sound harsh or bright unless from a very poorly designed amp, it’s academic we are not discussing poorly designed amplifiers and if you level match many properly designed amps will sound very similar, as to being without harshness and or brightness , its mostly there clipping /recovery characteristics is what really affects what most people hear and of course their choices ..!
Maybe you can explain away these high levels of distortion from toobs Or does distortion only matters with SS amps ....?
1 Audio Research REF 160S, Triode mode, 4 ohm tap, THD+N (%) vs frequency at 6.3V into: 16 ohms (left channel green), 8 ohms (left blue, right red), 4 ohms (left cyan, right magenta) 2 ohms (left gray).
