If you look at Page 5 of the Owner's Manual for the INT-60 (https://passlabs.com/images/uploads/manual/INT-60_om_quick_start.pdf) you'll see that although the remote itself has a Display button it's not used on the INT-60.
Dim, yes. Off, no.
On my unit...it does nothing
I was going to say Joe; you said that was on the INT-30. Are we sure, that holds true...for the 60.
And apparently not! BOO :wacko:
It would be a shame if you let that deter you from a great integrated.
No Bruce; I wouldn't let that be a deal-breaker. But I do hate it...when designers skip something, so simple to implement; that at least some...would find useful.
I think the Pass remote works for all the Pass integrated amps and preamps; not all the features are implemented in any given model.
In many systems I'm sure the INT250 will sound better than the INT60; in my case it's almost twice as much money, though, and the INT60 sounds so good
Still good, in fact I haven't really been thinking about my system for the last several months, just enjoying listening to music
The first part shouldn't be a problem. My room is at least 50% bigger, my speakers' rated efficiency 90 dB 6 ohmAny updates on the INT 60? I'm almost ready to pull the plug on one. Can these drive 89db 8 ohm speakers to reasonable levels? My room is small at only 10X16.
I'm also thinking of switching to Magico S1's. Anybody have any experience with the INT 60 and Magico?
