Customer decided to upgrade to all 9011’s. We did the install today. Incredible system.
It just goes to show that you don’t need to have a huge room to handle an ultimate system, when it’s set up properly. I bet it sounds amazing!
Ken
When I saw the pics I was thinking the exact opposite. I'm sure Mike can vouch for the sound but I would think that more space would allow it to breathe better. You only have whatever space is available though.
Ken
I'm a bit confused. I thought the customer already had 9011's? Or did he have 9007's earlier?
The speakers multiple adjustment points make them adapt to 14 x 14 or larger spaces. This room is 16 x 18 and sounds wonderful.
Mike,
Do the MBL 101E MkII speakers have similar adjustability options? What would be the minimum and optimal room size for them?
Thanks,
Anshul
They have three adjustability options: tweeter, midrange, bass. The Xtremes have far more, especially with the sub towers.
Room size for 101e mk2’s? 12/13 x 14 minimum. 15 x 20 or bigger is ideal.
Does this system have any kind of power conditioning? If so, what kind of wiring/cabling is used between the power conditioner and the outlets in the wall?
