Placed my order today for a Black X1. Now comes the hard part. Waiting.
Prepare to be amazed! Compared to the S1 it replaced, the soundstage has opened up in all directions including in front of, behind, to the sides of and almost extending to where the surrounds would be in a 7.1 speaker arrangement, and in height as well when used with my B&W 800 stereo mains.Placed my order today for a Black X1. Now comes the hard part. Waiting.
I asked the same question and the answer is that on the X1 only one output can be active at the same time. You will have to manually switch outputs as needed.I am going to use the coaxial output of the Lumin X1 to drive an inexpensive DAC capable of accepting 192khz-24bit to directly drive a headphone amp of mine when I want to do some private listening without energizing the complete 7.1 channel system.
Looking at the X1's active audio output options with the Lumin app, it appears that only one of the three outputs can be active at any given time. Is this correct or is it possible to have, let's say, both the Analog and SPDIF outputs active simultaneously?
Thank you.
That's DAC and cable dependent.
Hi, just setup my QNAP NAS with a folder with lossless/DSD files.
Is there a step-by-step guide to set up QNAP NAS music streaming to the X1?
