Ok, the Lumin U1 is working now!
I ran a 25 foot ethernet cable from another switch in another room to the U1 and it works fine so there is something going on with the switch at my audio rack. Interestingly, before I did that I did put the Lumin U1 in the place of another working device at my audio rack switch (my dac) using it's working ethernet cable and the Lumin was still not working.
Hi, wonder if someone can help me with this problem. I brought a chord Dave home for audition. I am unable to stream music with the USB connected to the Dave through my U1. I have tried everything possible including keeping the lumin unsampling off but just can’t get the Dave to play in the DAC mode
any compatibility issues that I am not aware of or am I doing something incorrectly. Grateful for some help
I did. I cycled a couple of times to ensure it’s on USB. It shows as USB 768khz on the left hand top corner as per display1. But no music. Not sure if there is some setting in the Lumin U1 I am missing.Nope. We use that setup in the store all the time. Make sure the DAVE is set to USB input.
Please power cycle both Lumin and Chord, try different cables, try different ports.
Hi, I should have mentioned....I upgraded to the new lumin X1 power supply which is available as an upgrade for U1 users as well
Hi, could you tell me what difference you noticed by changing the font, if there is a difference. Thank you.
Changing the Font? I guess you mean changing the power supply? Yes if so, my impressions are there in my previous post (#110). Clearly I could hear more detail, better bass delineation and soundstage width and specificity. I presume it’s all to do with lowering the noise floor even further.
Can I ask the price of the X1 power supply? Thanks.
