Amazon feedback from Jobsys website:
5.0 out of 5 stars
Job delivers 5 stars, June 4, 2013
By B. Cunningham
(Amazon Verified Purchase)
This review is from: JOB 225 2-channel Power Amplifier (Electronics)
So far so good. I tracked the package from Switzerland to the USA in about 3 days. My package suffered some abuse in route with one of the plastics straps on the outer box having come completely off, and the box exterior deformed. Fortunately the inner box largely survived and the amp was unharmed. Personally I think the packaging should be a bit more robust for this journey. But it does come encased in a nice elastic cloth bag and suspended in foam.
Aesthetically the Job faceplate is very beautiful, and the rear heatsink is more robust and nicer than expected. The remainder of the chassis is fairly average and the rear speaker outputs being largely plastic are the only bit hinting at cheapness. Thusfar, I have pulled a high end Jeff Rowland Concerto out of my biamped system and inserted the Job to handle the frequencies below 500hz. The Job sounds more controlled in this region and seems to mate more seamlessly with my 300b monoblocks driving the upper frequencies.
I am impressed and happy with the purchase. It is a small yet sweet amplifier. It does generate a fair bit of heat which is a good sign in my experience. After it warms up fully, you will be challenged to keep a finger on the heat sink for more than 4 seconds. Other than the packaging my only complaint is that the yellow-orange LED on the front panel is too bright if you like to listen in the dark.
Update 6/20/2013: After living with the amp some time now I have found that the heat generated by the amp has surprisingly dropped dramatically. I do not understand why this should be but after some breakin I find the amp runs much cooler such that you can keep your hand on the heat sink indefinitely, bizarre but that it what I have observed. Additionally, I should comment that the only negatives I have found is that the amp produces significantly more hum than the Jeff Rowland it replaced. Furthermore I do get some popping on the woofers I am driving if I do not turn them on in a specific sequence. All and all I still find it to be a great amp that powers my sub 500hz speakers beautifully.
