Rnrmf
According to Hifi Rose, their Apple Music implementation doesn't do lossless.
That's unusual since Apple only streams in lossless (and hi-res) afaik.
I did a update on the RS150b last night. It was interesting in how it updated at least interesting to me. It was a three part update. Meaning it updated and then prompted to update the unit again and then a third time. I was wondering if there was a bug and it might brick my unit so I just went through the process. It finished the update and the unit is fine. And works as before the update. It does have the Apple now active on my iPad and iPhone but I don't have a Apple Music account active. So, I can't report how that sounds or works. As Mike posted "high resolution is in works". I am able to set the screen to display the time while I play Roon however I was playing from one of my play list and after each song change the display will go back to the original cover art on the display this also happened when playing a complete album. Looks like another update will have to correct that. The VU meter option when using Roon shows a message "this function is not available". It's good knowing that HiFi Rose has the ability to do a software update as easy as my Tesla.
I'm running Roon with my 150B and the VU meters work just dandy. The McIntosh style meters are cool.
Pretty sure the "base" rate is 256k AAC, with "upgrades" up to 24/192 (although I don't know how many albums are available at 24/192). I don't subscribe so I may have some details wrong (I get solicitations to join 1-2x/wk).
That's interesting. Maybe I'll reboot the unit. I usually only use the clock or meters using the toslink. Did your install have more than one update process?
Here is the HiFi Rose forum webpage on Apple Music.
Information about Apple Music service - Notice - HiFi ROSE
Are you using the DAC in the 150b or USB out to the DS Jr.?
Mine updated with one take.
Has anyone used the Rose RSA780 CD player / ripper with the RS150? I'm considering the RS150 and the low cost of the RSA780 may sway me if its sound quality is up to scratch. Thanks. Peter
We have. It’s excellent.
Thanks Mike. I'm way outside your catchment area unfortunately or I'd visit. It's a long treck from Portsmouth, UK!
I want to improve my electronis (from the NAD M33) and have in mind the RS150 and a power (or more likely integrated) amp around the $6K range. Thinking of Hegel H390 or perhaps H590, though the latter seems over kill with Avantgarde Duo XDs. Peter
As I have been pondering a change to my digital stuff, this HI FiRose 150 B has caught my attention. Interesting one box solution to a streamer/media player and CD player (with a small simple add-on).
I wonder how the sound quality would compare to my present Bryston BDP 3 player and BDA 3 DAC.
I know it's a long shot but might anyone have an idea or guess?
Thanks,
John
The combination of RS150 and its compact USB-connected CD drive is indeed an attractive combination as it can act as CD Player, CD Ripper, HD Music Store, Streamer, DAC and Preamp. It can also directly access Youtube files and strip out ads and send the video content to a connected TV. This is surely better than using a PC to access Youtube files and send audio to a hi-fi system - complete with all those annoying ads!
I can't help you with comarison to Bryston, but the dealer who demo'd the RS150 suggested that, from a sound quality viewpoint, the Auralic Altair G2.1 may be a better bet, though of course it offers far fewer features.
My own major criticism of the Rose is it's poor control app. I use BluOS to control my NAD M33 on PC, iPad or Android (also available on Kindle, Mac and the likes of Alexa) and it's very nearly as comprehensive as Roon. I suspect the most Rose owners would find they need to cough up for Roon's hardware and subscription requirements. So, I'm sticking with my exceptionally good M33 until I find something that genuinely offers better SQ and matches its BluOS app capabilities.
I hope this helps. Peter
Peter & MEP-
Thank you for your responses. They certainly gave me additional perspective.
Apparently, the 150b does a lot of stuff quite well in some pretty well healed systems.
My primary interest is listening to CD's, ripped CD's and Qobuz.
So, as the "research" continues, again, I say THANKS!
John
