u-sound
Re: Gryphon Essence amp & preamp
i am wet
			i am wet
Hi @GSOphile,
Good point - Short answer is speaker physical size, bass management and the limited amp power. Usually going up in performance means also going up in size.
If I had the room, I would have gone for Vimberg Mino's but then I'm not sure I would go for this essence combo as power might be tight.
I've looked at A5, I like them but I'm scared that they're going to load the room with too much bass and also aesthetically they're bigger and I found them less balanced at the A3. But I'm still thinking about them.
Other speakers I have considered are the joseph audio perspective graphene 2 but I can't audition them.
S
I also think it would work out nicely. The mino is my dream speaker but it's physically too large for my room.
It would take too much real estate and I wouldn't be able to separate them enough from the back wall.
I've asked a dealer about the Amea's but he's told me they're tricky to operate. He hasn't been able to make them sound right yet.
I've even considered moving to accommodate the mino's...
In the meantime I have to consider "smaller" speakers to fit the space in my room...hence leaning towards the A3's...
Alternatively maybe moving up to the A5...but I'm scared they would overload the space
Hi Calvin,
Thanks for chiming in, appreciate it.
You have a nice room, the A5's would work out for you.
I've uploaded a couple of pics, see what I mean when I say I don't have a lot of real estate!
The tape on the floor is because the elements dont fit into my rack.
I'm considering putting marble behind the TV to be able to fix it on the wall and then create a marble stand for the elements.
I have to do it like this because at the moment the doubling of the wall doesnt allow to fix the tv on it since the door slides inside the panel behind the tv...
Yup I'm with you concerning A1's plus I don't like the look of bookshelves.
Sadly I can't push the walls! I keep on looking but I keep on coming back to the A3's...
Catching up. Where are you at with your decision to go with Essence? IMO, without listening, you can’t go wrong. And in time, you will have the ability to upgrade your speakers. Perfect
Ah, my bad. I just realized you bought it/them. For some reason thought you were still auditioning.
No I haven’t bought anything then
I’m pretty close to pulling the trigger. Most likely next week
Yes I want a simple streaming system. Thinking about using the new aurender N20 as a source and going for the Zena DAC module of the preamp for simplicity reasons.
