Interesting DSD chatter from WBF:
Actually, you're a lot closer to being right on than you may think. DSD (1-bit two level Pulse Density Modulation) isn't digital in the first place, it's ANALOG! PCM is digital, in that it's a sequence of discrete 2's complement binary words of n bits, with each word being a stand alone digital expression of an analog signal level, at the sample time. It's just like frames of movie film, strung together to convey motion.
DSD, a Sony/Philips marketing term for a 1-bit two levels analog format is as analog as AM or FM radio. Like them, it's simply a signal modulating a carrier for transmission purposes, and detected at the receiving end to retrieve the signal. Unlike them, instead of modulating the amplitude or base frequency of a carrier, it modulates the density of pulses. This occurs as a hunting/feedback process in a Delta-Sigma Modulator, creating a pulse stream clocked at the sample rate who's density is proportional to the signal level. No frames, no words, all continuous, and most distinguishing, no weight or value! That's why it has to be either converted to PCM to be processed in a computer, or converted to multi-bit Pulse Density Modulation, ala the Sonoma DAW.
Since it by definition has only two levels, a computer can store and retrieve it, just not process it, because it does not represent actual sample values. All it represents is change of levels through the density of the pulses in a continuous pulse stream. The higher the level, the denser the pulse chain. ANALOG!
That's why you're correct saying just filter it, and get the signal back.
I know Tom. I have such a DAC. ... a Lampi DSD-only Dac and I know the motion picture film analogy and why DSD is MORE bit efficient than PCM. People mistakenly think its about comparing resolution, but its about how much new info each packet in the stream brings. DSD references the CHANGE.
The philosophy for the Lampi DSD Dac is that it's essentially ANALOG and treated totally in the analog domain.
Originally Posted by Andre Marc
Wow..I have not seen it explained so clearly, thank you!!!!"
And when it is explained that clearly, it is obviously wrong.
DSD is just as digital as PCM, in that the signal is stored in discrete, quantized values at a constant sample rate. Just because one system uses a higher sample rate but a smaller number of bits (1, in the case of DSD) doesn't make one "analog" and the other "digital". DSD is pulse-width modulation, but the width of the pulses can't take arbitrary analog values - the resolution of the pulse width is limited by the sample rate. Standard DSD, with a sample rate of 2.8224 MHz, thus uses a digital data rate of 2822 kBit/s per channel (comparable to the 2304 kBit/s of 24/96 PCM - but because DSD is usually considered equivalent of 20/96 PCM, we can see that PCM is somewhat more efficient).
Yes, digital PWM data is easier to convert into an analog form (all you need is a low-pass summation filter), but it still can only take set, quantified values (unlike analog that forms a continuous function that can take arbitrary values).
"DSD-wide", as used in "DSD" editing and mastering systems, is 8-bit PCM, but still at the 2.8224 MHz sample rate, while DXD is pure 24-bit PCM at 352.8 kHz.
Ahhh Julf,
You dont even need filtration to play back DSD. Just connect it to a speaker and you get distortion filled music, so there is NO conversion going on, and thus its more analog than digital. Its a finite pulse representation of a continuous waveform without any coding.
So you are BOTH correct.
DSD is more bit efficient though, as it reports the changes from initial reference and not the status quo plus incremental change like celluloid movie recording & PCM.like celluloid movie recording & PCM.
