Hello HongKong.
What is making you consider an upgrade from Rowland 625? Power? Resolution?
For one thing, the Accuphase A200 seens to deliver 100W in stereo mode over 8 Ohms.... All I found is that in mono mode, the amp would deliver "even more".... THis suggest that power would not double in mono/bridged mode.
Conversely, the original model of M625, delivers 300W over 8 Ohms. The S2 version outputs 325W/8 and 600W/4.
The S2 version is much enhanced over the original, which was already a stupendous device.... Is your 625 an original model? If you call your dealer or distributor, they can arrange for the upgrade to S2 status. Not sure what the upgrade price might be in France, but I know it is quite reasonable in the US.
If you needed even more power than the Rowland M625 S2, the new Rowland M535 in mono mode will deliver 900W/8.... All reports I have heard about this amp point to it being quite spectacular. I may be receiving a unit to evaluate in the next few weeks, and will post my detailed findings on Audioshark.
Regards, Guido
I am not sure if you would find the Accuphase A-200 to be an upgrade from the Rowland M625... Even if your M625 unit were an original model, and not the much enhanced M625 S2.
would
