Cable cooker
the professor
Oregon Coast
Has anybody used a cable cooker type device?
I know Nordost has a device that dealers have. I was talking to a dealer that has one and he was saying that even broke in cables sound better if he uses the cooker ever 6-9 months even tho they are in a system.
I had never heard of that before.
Does anybody know?
I have a Audioharma cable cooker, I think ver. 2.5. I think it really does work. I'll post a link when I can. They made some changes to mine like a bigger frequency sweep. The one the Nordost dealer uses is supposed to be maybe even a little more powerful.
I use the Audioharma 3.5 anniversary version and it does a great job.....re-cooking the cables seems to rejuvenate the cables a smidge, sort of like cleaning connectors.
Here is mine
[TD="width: 625, bgcolor: #FFFFFF, align: center"]
[email protected]
[/TD]
[TD="bgcolor: #FFFFFF, align: left"]
Representing
only those
designers whose
innovations are
pushing the
musical envelope
[/TD]
[TD="width: 889, colspan: 3, align: center"]
[/TD]
[TD="width: 889, bgcolor: #FFFFFF, colspan: 3"]
audiodharma CABLE COOKER™
FACTORY DIRECT PRICING
Standard Plus version 3.5....$849
(features gold-plated, color-coded, hex-shaped plastic binding posts)
(now includes bridging switch circuit )
Anniversary Edition 3.5 with Cardas ACBP binding posts....$999
Anniversary Edition 3.5 with premium all-copper billet Cardas CCGR binding posts....$1149
Plus $20 insured shipping within the continental U.S.
Please read the FAQ page prior to ordering.
To see a full list of custom adaptors, please click on the Adaptors tab above.
EFS CIRCUIT & FULL CRYOGENIC TREATMENT
After many years of outstanding performance, we pushed the design envelope
and configured a perfectly linear, extended frequency sweep circuit (EFS) that more than doubles
the previous sweep at both ends of the spectrum....quite an achievement.
The EFS, of course, compliments the high voltage / high current components of the signal.
The swept square wave starts at 0 DC and is calibrated at just over 40KHz,
whereas the previous sweep (for version 2.5) started just below 40Hz and reached 18.5KHz.
The Extended Frequency Sweep (EFS) improves on every sonic parameter,
translating into more transparency and dimensionality, a deeper/wider soundstage,
and deeper / tighter bass information.
Full cryogenic treatment of the circuit board, all chassis connectors, switches, and internal wiring
is included with all Standard Plus 3.5 and Anniversary Edition 3.5 models.
Note: this cryogenic treatment is also available as an upgrade for all Cable Cooker 2.0 & 2.5 owners.
It is as sonically significant as the EFS circuit upgrade, and the benefits are cumulative (click on Upgrade tab above).
All Cable Cookers come complete with an outboard universal switching power supply,
one set of power cable break-in adaptors (US-style for US customers), one power cable extension adaptor
(for daisy-chaining, US-style), and 3 pairs of RCA barrel connectors (for daisy-chaining RCA interconnects).
UK13 and Schuko-style power cable adaptors are extra for all orders.
Version 2.5 units may also be upgraded with Cardas ACBP binding posts ($175 including labor and re-termination).
The premium all-copper billet Cardas CCGR's are an additional $100 option.
(see Upgrade tab and close-up pictures at top of page)
Stereophile Recommended Component for 3 Years Running
    THE CABLE COOKER™ 3.5 GREATLY IMPROVES the sound quality of all forms of interconnects (including A-V and phono), speaker cabling, AND power cabling beyond any normal break-in cycle.
    RAPID, SUPERIOR BREAK-IN AND CONDITIONING ... conditions more thoroughly because the cabling is exposed to extreme signal levels and a special waveform that does not occur in normal system operation.
    SOPHISTICATED, HIGH-EFFICIENCY, CONTINUOUS DUTY CIRCUIT supplies in excess of 1 watt for interconnects and 22 watts for speaker and power cabling, in addition to a highly dynamic extended-frequency sweep (from 0 DC to over 40KHz).
    UNIVERSALITY OF USE ... allows break-in and conditioning of interconnects, speaker cabling, and power cabling simultaneously.
    INTERNATIONAL COMPATIBILITY... universal switching power supply may be used on any continent....usable with all line voltages from 90VAC to 260VAC, and AC input frequencies from 47Hz to 63Hz.
    CUSTOM ADAPTORS available for daisy chaining power cables and speaker cables.
    DESIGNED & MANUFACTURED IN THE U.S.A ... BUILT TO LAST
    TWO-YEAR FULLY-TRANSFERABLE WARRANTY (parts & labor)
[/TD]
What custom adaptors are available with my Cable Cooker? (all adaptors are cryogenically-treated at -320F. for improved conductivity and superior performance)
extra 15-amp IEC power cable adaptor....$16
(initial unit is supplied with every Cable Cooker)
15-amp IEC to NEMA-style wall plug extension adaptor....$10
(for daisy-chaining 15-amp power cables)
20-amp IEC power cable adaptor....$40
20-amp IEC to NEMA-style wall plug extension adaptor....$50
(for daisy-chaining 20-amp power cables)
custom Schuko power cable adaptor....$30
custom Schuko-to-15-amp IEC extension adaptor....$40
(for daisy-chaining Schuko or Euro-style power cables)
custom UK13 power cable adaptors....$40
custom UK13-to-15-amp IEC extension adaptor....$50
tonearm wire/phono cable break-in adaptor....$90
custom set of speaker cable break-in adaptor boxes....$65
(one set for each additional pair of cables--made with five-way binding posts)
Do they make one that does AC too?
They have adapters that plug into the binding posts that terminates to an AC connector....plus they have adapters to daisy chain so you can cook multiples at one time.
The phono cable adapter is a must have......because the tone arm wiring and phono cable really never breaks in completely because of the tiny signal in the analog chain. You really haven't heard your phono cable and tonearm wiring at its fullest potential.....they really never completely settle in with out cooking them!
Ok. Email me price for everything.
At first I was wondering if I should post here (mainly for the girls members); now I don't anymore. ;)
_______________
Are there cable manufacturers selling already "cooked" cables? :)
LMAO. They apparently have pills for that now Bob.
