highstream
- Dec 7, 2013
How much do your subs weigh? The Music Room in Colorado has good prices on the Gaia models and HiFi Shark is a good place to watch for the used and sometimes new market.
I’ve been considering them for placement under my new subs. At $189 ea for the 4” product (I need 8) I’m likely to pursue a different solution. Maybe I’ll give the ISO Acosutics ISO-Pucks or the Orea Bourdeax a try.
If that platform’s bottom has threaded holes then Gaia 1’s would work. The Music Room advertises them for $430/4 (hifishark.com) and you might do better asking them what they’d be willing to do for 8. That’s a lot of weight, and I can’t imagine Iso-pucks or Oreas cutting it sonically. Beyond that, the Townshend platform products are very well regarded, but they are out of England, so the importer adds a cut. Home | speaker isolation.
Four are usually better than three for components...
That's my experience with vibration feet too.
I use 3 with my Lampi TRP too, but that's only because I'm hesitant to take off the feet that come with, which are supposed to be an isolating product. I use four under everything else, though, based on comparisons.
I think you meant Gaia I or II. If you check the weights, the II only goes up to 121 lbs/4. What I learned using III's (72 lbs max) under 68 lb speakers, running close to the limit doesn't cut it. The EVP's provided easily superior isolation to the III's in that situation. Sean Morrison of Isoacoustics had suggested them, then later apologized for misguiding me, saying leave at least 10%. My thinking is more leeway. In any case, I have a set of II's and may give them a try one of these days.
Mike,
You could also potentially use 2 of the new EVP Platform, one under the front of the sub and one at the back, rather than four, one at each corner. I'd price them out and see what's least expensive. Also, I know these are somewhat pricey for the 4" square versions, but my recommendation is to order them and try them out.
Here's something to consider: Yes, they're a bit pricey at $189/each for the 4" square versions, but here's the deal...they are WAY less expensive than having your room re-constructed to solve the same exactly problems these will solve by putting them under your sub.
They come with a 30-day money-back guarantee, so you can use them for 30-days, and if they don't work out, return them for a full refund.
Oh, and for a sub, the correct IsoAcoustic footer is an Gaia II or Gaia I, depending on the weight of the sub. I don't think the ISO-Pucks are designed to support the weight of your subs. Moreover, the Orea are for components, the Gaia series are for speakers and subs. Different products for different applications.
Please keep us apprised of what you decide, and what works out for you, but I will say that putting these under my sub made one of the biggest improvements I've ever made to my system because they made the room considerably quieter.
Cheers!![]()
