BayStBroker
- Jan 15, 2015
I wonder what volume levels many of you on Shark use for critical listening? I also wonder how high you tend to go when you "rock out." I prefer to listen at around 85db on average, and I will go up to 102db if I want "to get the Led out." I suspect I am listening too loud and that I should bring it down 5-10db.
I enjoyed the following brief comments from a member of a different forum who posted on this topic:
"When I was a recording/mixing engineer, I was taught to monitor at between 80 and 90dB SPL as that was the level that our ears had the flattest frequency response, relative to the Fletcher Munson equal loudness contours: The SouthSIDE Of The Tracks - Glen Stephan - Independent Recording Network
The film industry has adopted 83 db SPL as the standard to mix and listen to. And Bob Katz, a mastering engineer, has put forward a recording industry proposal that states the same 83 db SPL listening level as well. How to Make Better Recordings Part 2 - Digital Domain: CD Mastering | Mastered for iTunes | Audio Mastering | Blu-Ray Mastering
For critical listening, to get the same effect (i.e. tonal balance or timbre) as if I was sitting in the mixing chair, I would listen at the recommended 83 db SPL. But if I wanted to rock out on my http://www.computeraudiophile.com/blogs/Rock-n-Roller-s-Guide-Designing-Audiophile-Sound-System then a much higher can be fun!"
So Sharks, how high do you like it? And how high do you go?
