Hey all, it's been an eventful 2020 for us all and as such I have been in lurking mode for most of the year.
But I am coming out of hibernation to share the results of a major room overhaul this weekend. Since my last system update in February where I was introduced to Naim for the first time (Uniti Nova) I have moved up the chain to a Naim separates system consisting of the Supernait 3 and NDX 2 streamer.
As a result of having my home theater and 2 channel system in the same room however, I was running out of space for the "required" Naim power supplies. Until it dawned on me that I had an entire other half of a room BEHIND me that was being unused. Which was also really intriguing because I have long thought I could get better imaging out of my system if I eliminated the console and wall-mounted TV from between my speakers.
So long story short - due to not having usable corners on the other side of the room I decided to experiment with the Cardas placement for my Volti Rivals. Using their online calculator I determined optimal placement is about 7.5' from the back wall with about 4.3' from each side wall.
After setting this up and re-arranging amps, subwoofers, and power to that side of the room, I worked with toe-in for a bit and found that this set up is actually jaw-dropping from an imaging and soundstage standpoint. It is as though the band is performing about 3' feet back and inside the speaker stage - almost like a hologram. The effect is especially stunning when listening to just a singer and instrument, such as Eeg Fonnesbaek's "Willow Weep for Me."
I would bore everyone with another paragraph of superlatives but suffice it to say the system is staying put right where it is. And I finally have room to add an XPS DR power supply for the NDX 2 which will complete my Naim 4 box system.
Here are some pics of the final arragement
JSQT's Media Room November 2020
