I've previously read an external crossover is required to control both the sub and main speakers to properly integrate low/mid level frequencies. Thus I had been considering buying a JL Audio CR1 crossover and possibly a matching e-sub.
But last week tried using one channel from my JRDG Corus to the line level input of my Definitive Technology SC8000 sub, setting the crossover point 40 Hz. I had previously only used the sub for movies surround sound, it's located in the rear of my room.
Since I'm using only the subs internal crossover, full bass is still being passed to the front speakers. I expected to hear bass overhang, but to my surprise there's very little to my ear. The low/mid frequency integration may be better with an external crossover, but this change has made a significant improvement with my stereo listening. Not only am I now hearing tight low level bass with punch, but the soundstage sounds even bigger.
I'm buying a pair of reasonably priced DH Labs subwoofer cables to feed both line level sub channels from the Corus. Although both Stereo channels are mono and contain the same frequency output, I've read using both channels provides more gain.
I'm planning on using the existing single cable from the A/V receiver LFE output to the sub LFE input for movies.
