Musicfirst
- Apr 9, 2016
Do such animals exist?
A sub being ‘fast’ is more about how it is integrated with the mains than a brand, style, or type. To be ‘fast’ a sub must time align with the mains, which usually means some sort of external crossover that has the ability to delay the acoustic output of the mains so it matches that of the sub.
Wouldn't it be better to have the crossover/low pass filter in the sub(s) provide the necessary electrical characteristics to mate seamlessly with the mains?
For seamless acoustic summation, both the high and low pass electrical filters matter and more importantly, the physical spatial position of the sources. The latter being the bane of most separated subwoofer setups. The low pass filter itself creates a delay, often compounded by the greater distance of the subs away from listener, vs mains. Without delay for the mains (usually 99.9% non existent), proper phase (and thus frequency) integration exists only in the mind, vs the actual room. The room of course, also plays a very large part in both integration, amplitude smoothness, decay and "speed" of the bass.Wouldn't it be better to have the crossover/low pass filter in the sub(s) provide the necessary electrical characteristics to mate seamlessly with the mains?
Great question - the reason crossovers/equalizers in subs don’t solve the ‘fast’ problem is that the group delay of a modern sub is large enough (especially if it has some kind of digital eq built in) that the initial direct sound from the sub will be delayed with respect to the mains. So you need an external crossover to add delay toWouldn't it be better to have the crossover/low pass filter in the sub(s) provide the necessary electrical characteristics to mate seamlessly with the mains?
Of course if you sell $3000 outboard crossovers you will contend that's the best method.
