SCAudiophile
My great experiences with REL for 2-channel and home-theater is more than a bit dated given ownership of B1 Britannia(s) preceded by Stadium and Stentor.
Other than what I've found online in terms of the obvious "RTFM" differences in low-frequency specs., amplification differences and WiFi (No. 25 and 212SE),
what would those of you with experience with these 3 models have to say about the No. 25, G1 and 212SE performance for a full-range 2-channel only
setup that is used to play everything from pipe organ, taiko drumming, jazz, classical, new age, fusion, R&B, Techno, Rock, Prog-Rock, etc...i.e. the
full spectrum sans Rap and Country? Speakers and system overall are in my signature and posted elsewhere on this forum.
How close in particular is the performance of the 212SE to the No. 25 for 2-channel listening only?
Does the use of the classic REL Class AB amplification (which I always loved in my B1 and prior models) give a more musical response than their
newer Class D designs and is it worth grabbing a G1 for my purposes and living without LongBow/WiFi?
There are also a couple of 9/10 condition B1 Britannia still available out there; that sub excelled (at least for me and my system at the time) at
2-channel as well as standing tall in a HT installation. I'm tempted to grab the B1(or plural) and go with what worked well for me before but I
do see differences in the latest offerings that has my attention. The 13 Hz +/- 6db spec and real-life performance of the B1 was a hard act
to follow so I'm looking to make the best choice possible to firmly tap the region of sub-bass from 21-23 Hz on down to pipe organ and synth
foundation frequencies....
***I have always loved the high-level 100K ohm input method REL pioneered and think it is superior for 2-channel blending.
Many others favor low/line-level input subs with DRO and other forms of digital integration (Velodyne, JL, etc...). Not meaning
to start a philosophical or audio-religious bonfire here, but to all of your minds and ears out there,....does REL still stand up
as one of the best in 2-channel subwoofer integration and musical quality? Any other brands I should be considering?
Thanks in advance for the help!
