Outlet Covers with supports for plugs
Cincy2
Tampa FL
Anyone know of a source for electrical outlet covers that have a support for heavy power cord plugs. I had one that was 3d printed but it broke after only a few weeks.
Thx
Eric
Yes! Exactly! Mike - you are the MAN. I have Furutech outlets. I'll figure out which ones I want and give Matt the info.
Thanks
Eric
Those Block Audio C Lock covers work like a charm and they make a version especially if you use the Furutech base plate.
I love mine!
This seems like a good product. Do they make a triple version? I didn’t see anything other than a single outlet on their site.
No triple. They do make a double, but it’s for a small power cable. Best to stick with single only. There isn’t room for the C-Lock and more large outlets.
Well, that is probably a good thing since I suspect it would cost at least $500. However, thinking about this it seems like a relatively easy niche market to get into. All the outlet cover needs is a strong, supportive U shape under each outlet to handle each cable. Feel free to take this suggestion and produce it. Just let me Beta test it. :)
Since we’re the American Distributor for Block Audio, we probably won’t be competing with ourselves. [emoji6]
They are $350 if you’re getting them with the top of the line Furutech outlets built in.
Otherwise:
Block Audio C-Lock Lite Power Connection Guard - Suncoast Audio
