UltraFast69
Years ago, I used Optical cables in my Home Theater System well before High End Audio. Since that time, my appreciation of cabling has developed to the point of sickness. Anyway, many of us are aware of Optical filters from reading, writing, commenting about.
I started to wonder about the open Optical slot out of my Transport and the open optical in of my DAC.
I am going to do a test using an older Audioquest Optical cable. I have the ability to go back and forth toggling the input on the remote control between the Digital Coaxial cable and the Optical cable.
From my understanding, HDMI has taken over perhaps from a production standpoint as its more economical to use one cable versus two, but I would think that’s more related to the A/V portion of the industry. I recall Nordost used to make an Optical cable, and does not anymore, but not sure the reason, and I hear Audioquest Diamond is supposed to be the cats meow still in production.
I am wondering what the Optical Toslink connection will do in performance? Does it compare to the Gigafoil, TS Link and other systems that are out there?
Gonna still try it, but any comments?
