I can't ever remember seeing another perfect score:
http://www.hometheater.com/content/oppo-bdp-105-blu-ray-3d-player
I really wonder if the 105 sounds better than the 95 through the analog outputs.![]()
It certainly throws the whole cost for performance ratio out of whack! Those guys at Oppo are amazing. What a great success story.
+1. I've had a couple different Oppo players through the years and their products and service dept. are what all companies should strive to be like. Top notch for sure.
+1! I have three Oppos and love each one of them. Even my 5 year old 980H works flawlessly. My next universal player/streamer will be an Oppo as well. No question.
Esteban, Can you compare the Oppo 95's analog out to the newer/cheaper 103? Does either unit have an advantage when using USB in?
The studios are good too! I heard them. One thing I have learned, often the hard way, is that systems have to be matched well. I needed strong amps on the Salon 2 and started with the Krell 750mcx. The step up to the 600i was gigantic and major improvement. In fact, should I ever get the funds I want to switch the 450mcx that I have for the center to a 400i.
How long until your speakers get set up? And do improved power cables make that much of a difference? That is a question, not a statement, I don't know.
