Hello I´m writing from Buenos Aires Argentina.
Regretfully I´m suffering some strange problem with my beloved Lumin
As you know I have a Lumin A1 since 4 o 5 years and till yesterday it worked really fine but suddenly there is no sound coming form the streamer.
The streamer seems to work properly, I can see the information of the album and the minutes/seconds running on the App but no sound goes to my preamp.
First I thought there could be some problem with the cables hence I checked interconnection cables (XLR) and seems to be ok. Then I also checked the Power cable to the PSU and no problems there.
So I plugged up some RCA interconnection cables but the same no problem no sound coming from the streamer to my preamp also with this new RCA cable.
I decided to switch off the PSU and wait some minutes... I did so and switched it on again after 10 minutos aprox and the sound appear again.
I though the problem was solved but regretfully after 3 minutes again no sound on the Lumin.
I was really frustrated yesterday hence I disconnect the PSU from the 220volts socket till this morning.
Again I checked (with my finger crossed) and same problem the sound appear for 3 minutes and after that silence again even though the track is running (I can see it on the App)
Any recommendations..? Any thought..? Is there some way to reset the Streamer...?
I will be waiting for your comments.
Thanks in advance for your cooperation.
Best Regards;
Best Regards;
