Hello everyone,
I'm completely new to this type of gear and these kind of forums. (so please forgive any rookie mistakes). I'm finally in my journey to understanding how to built a good audio system (hope it manage to educate myself slowly and surely its never too late). Honestly all my life I've believed that one needs a lot of money to buy good gear but I think now I see that is not the absolute truth (to some extent it will always be true) but if once approach is correct and with time one can keep upgrading get a sound one likes or prefers.
So my first purchase was a while ago the 5.1 focal dome flax for my movie set up. I got an Harmon Kardon AV receiver with it ( came free ans still works fine has airplay and sportify and i use apple music until now.
anyway, my real journey towards stereo sound system started recently when I purchased a Luxman L 507 Z integrated amplifier. Now i need to buy speaker that go well with it, budget is modest for now roughly $ 2500 or so. To be honest I didn't think this through, I got a good deal on Luxman in Japan so i bought it there. (it's way cheaper in Japan) Now I wonder if I should use my tower speaker as the front 2 in the 5.1 and use the luxman to power them ( this will most def elevate my movie experience) and also be able to use the towers as a stereo for music only ( i have a mid size bedroom roughly 20 feet X 12 feet) The center and surround could use power and signal from the AV receiver.
But someone said that I'll need a home theater by-pass on the Luxman for that (which it doesn't have). I'm not sure how to go about it. or if it's even a possibility?
besides that I'll need recommendation on speakers and what all should i consider. I'm based in India and the gear gets expensive by the time it goes through customs etc.
I was looking at Spendors A2 or A4 (can't get much review on it) not sure of they will pair well with Luxman and do justice to it. Little on the higher side are B&W 603 S3 (not sure if this is worth it) or other options are KEF Q950, Polk R700, or Dynaudio Emit 50 ( all these option came from a local dealer) I'm happy to hear as many options from members here.
post that I'll need to address the Dac + streamers as well. Budget about $1500- S2000
i"m not sure if I'm setting a realistic budget or is it possible to spend less but get good sound without name like (lumin etc). I'd be glad to reduce the budget wherever necessary but i rather wait and buy something that works well then change every 6 months or 1 years. I'm happy to go with a cheap streamer and a good Dac since that's what I'm made to believe matter.
any thoughts also please feel free to burst any myths I believe are true.
thank a ton for taking the time out to read or reply.
