My "office" is nearly square with dimensions of 12'x11'x8'. I contacted one of the popular vendors for help with treating the room and they suggested starting with large stacked column style traps in the two front corners (behind the speakers). With two large panels at the back of the room (behind my seated position). With an option to add side panels and a ceiling panel for first reflections. I purchased the first and later added the optional. While the room sounds significantly better than before, I still get a loud metallic ring when doing the hand clap test. Should I be worried about this? Do I need additional panels or something else?
