Entech Line Noise Analyzer. That's what I use. I've heard the same from clients. I take the Entech to their house (and a Denali or AQ 1000/5000/7000) and the before and after is not subtle.
https://youtu.be/LxyxkCOlZsU
The Enteq is no longer being made. However, you can find some used ones on the eBay. The Enteq is useful for
rudimentary demonstrations. However, it is not a good device for a comprehensive study of power line noise. First, it is has no standard references settings. You plug it in - you adjust the gain with the knob until you get a approximate 100 reading on the meter. This is arbitrary - not a measurement where you could compare two different power lines and certainly not compare readings between locations. It is however useful for a quick before and after of the same power line. You must be careful NOT to touch the gain control between readings and the readings should be taken very close together since power line noise is dependent upon the radiated RFI/EMI noise in the environment.
A Fluke Model 43 power line analyzer is relatively inexpensive but it doesn't measure noise.
For actual scientifically accurate readings you need a spectrum analyzer that is specifically setup to do power line readings. We several including the Audio Precision Analyzer with power module installed. If you have a PC based spectrum analyzer DO NOT plug it into your power line! If you don't know what you are doing - don't do it. You must take very specific precautions when connecting measurement devices to a live power line.
The Enteq only detects and rectifies frequencies to around 700KHz which means is it completely insensitive to some of the most harmful noise frequencies - those in the 1MHz to 10MHz ranges. But hey it is inexpensive, easy to use and it is nice to be able to "hear" some of the stuff that is on your power line. Your dedicated power lines, rhodium plated outlets and large gauge wires in the wall in no way immunize you to power line noise. Power line noise is picked up from
radiated electromagnetic waves all around you. This includes AM and FM radio, wifi, cell frequencies and the list goes on. Furthermore noise reduction is always "localized". That means that just because you have a power conditioner that reduces conducted noise does not mean that the noise doesn't re-introduce itself farther down the line. So if you have some form of power conditioning at the electrical panel, the radiated noise will be picked-up by the in-wall wiring that acts like an antennae. This means you WILL have noise on the power line at the wall outlet. This is why we talk about the "
distributed power conditioning" approach to noise reduction.
We are actually working on consumer level device that is more a modern and elaborate version of the Enteq. It will detect a broader range of frequencies and they will be calibrated so that absolute readings can be taken. This will allow you to see if you have a low, medium or high level noise on your line. And it will allow people to compare noise levels at different times of the day and at different locations.
