That's interesting Larry as Andrew Quint noted in the TAS review "The Pass XA 60.8s didn’t sound underpowered; it’s just that one won’t regret having a big amplifier to drive any Magico loudspeaker."...and that was the mono's. Though I guess it is system and room-dependent :audiophile:.My 60watt Pass Labs amp is more than sufficient in driving them.
Larry
Larry it certainly sounds like you've had a fun journey, and worked out who's who in the zoo. I agree with my friend Paul that the Vitus SIA-025 is the most organic, tube-like amp in the current Vitus lineup. Certainly more liquid/tube-like than the SM-011 mono's, and a bit sweeter sounding than the SM-102 mono's. But they both sound great in their own ways, so i'm splitting hairs. Both Pass Labs and Vitus's smaller Class A amps tend to sound a bit sweeter and more tube-like than their higher powered brothers.Andrew auditioned the Magicos in a larger room 15x15. My room is 11x14 with my speakers on the skinny side. I had my doubts also whether I was missing something and a buddy loaned me a Vitus R-100 which is a glorious amp in its own right with 300watts per channel.
In the end I preferred the class A sound of my Pass and at the volume that the Vitus would overtake it I risked getting a visit from the condo police. Now I'm thinking how that sweet Vitus SIA-025 would drive them.
An idle mind is the Devil's workshop as they say :evil: :lol:.Yep, and that my friends is how your wandering thoughts get you in trouble.
+ 1. The S1 Mk2's sound like much bigger speakers in terms of their deep, well controlled bass & sound stage size. They also sound completely seamless as you've mentioned previously. Amazing performance from such a small form factor!The S1 mk2 is a "don't just a book by its cover" speaker. I had them playing in my big room and man oh man are they good. You can't believe the bass they put out in an 18 1/2 x 25 room.
I had both in my listening room. The Sabrinas have more macrodynamics and more bass slam, simply because they use 20cm vs 16cm woofer. That is a big difference in terms of sheer output. It is just physics, no magic here.
I was able to overpower (bottom out) the S1 woofers playing soundtracks with lots of intrasonic content (Braveheart) in my 14x19 listening room - sth which never happened with the Sabrinas.
Now, if we talk about the quality of the low freqs, than I agree that the Magicos are much better. The S1 bass is faster and more articulated, with much less overhand and boomines. In fact, I had to put sponges into Sabrina's ports to bring the bass down to acceptable levels (which made them a semi closed design) and avoid said boominess.
The S1 are more transparent, image better, have much better highs and more natural midrange, but they are still a small 2-way with 16cm woofer with all (bass) limitations of such a designs.
S1 mk 2:
Sabrinas:
