ohbythebay
A lot of people may know this, many may not..but the question is "Did you know that the Mr. Clean Magic eraser is one of the best and safest stylus cleaners out there ?"
It is. The original square pads are the most awesome non-damaging stylus cleaners around. No rubbing, no liquids. Just cut a small square that is easy to use (2" by 2") and you lower the stylus onto the pad a few times (straight up and down). It sort of a gentle pin into a pincushion. No residue , no rubbing .
If you just dip it into the pad 3 or 4 times, you are done. Proof ? Try it and look under a magnifier. DO NOT WET ...
How it works
HowStuffWorks "Melamine Foam"
So did you know about this?
Are you using this today?
If not, will you try it ?
Thanks
How it works
Thanks
