Is there a place that will test my Amp tubes??
For $600 this might be worth it.
The MaxiMatcher Digital Tube Tester is a compact precision measurement station for the test bench or sales counter. It's designed to test power tubes for the electrical characteristics of Plate Current (Ip) and Transconductance (Gm). Any of the standard octal-base power pentodes common in today's audio amplifiers including 6L6, EL34, 5881 and 6550 can be tested. With optional adaptors the MaxiMatcher will also test EL84 nine-pin miniature pentodes, Novar power pentodes, 2A3 and 300B power triodes, EL509 plate-cap pentodes and many others.
The MaxiMatcher is used by the audio tech, music store salesperson, or audiophile enthusiast to quickly test a tube for operation and quality. Start by placing a tube in the short circuit test socket and you will quickly identify the culprit that's been blowing all those fuses! The MaxiMatcher can be used to precision-select loose tubes into accurate sets for mounting in power amps, as a point-of-sale aid in selling matched tube sets or for verifying customer tubes at the sales counter.
The MaxiMatcher tests up to four tubes at a time, and has a separate socket for short circuit testing. Easy directions for use are provided right on the top panel and the layout is clear and intuitive, making the MaxiMatcher simple to use and easy to understand. Separate selector switches for Bias Voltage, Plate Voltage, Measurement Function, and Test Socket Select are provided, along with the proprietary SmartFuse high speed protection circuit, indicators and a mains switch. All test data appear on a large, bright 3.5 digit LED display. Digital measurements are made by a proprietary sampling A/D converter allowing high resolution measurements.
Features
  • Instantly identify weak or damaged power tubes
  • Accurately measure tubes for amplification quality
  • Precision-match tubes for plate current and transconductance
  • Real-world selectable plate voltages - 325 or 400 VDC
  • Test tubes for inter-electrode short circuits
  • Proprietary SmartFuse automatic protection circuit
  • Create matched sets of tubes for your customers
  • Inventory / QA check for OEMs or music stores
  • Sell your own label tubes
  • Very Rugged Construction
  • US 120VAC, Euro 240 VAC, Japan 100 VAC
[TD="width: 35"]
[/TD]
[TD="width: 467"]
[TH="colspan: 2"]
MaxiMatcher Specifications​
[/TH]
[TD="class: product_01"]Directly Testable
Tube Types[/TD]
[TD="class: product_01"]6L6, 5881, EL34, 6V6, 6550, 6CA7, 7581, KT88, KT90, KT100[/TD]
[TD="class: product_01"]Optional Tube Types[/TD]
[TD="class: product_01"]EL84/6BQ5, EL509, 7027, 7591, 7868, 807, 2A3, 300B, 45
(adapter required) click here for adapters[/TD]
[TD="class: product_01"]Plate Voltages[/TD]
[TD="class: product_01"]325, 400 VDC[/TD]
[TD="class: product_01"]Bias Voltages[/TD]
[TD="class: product_01"]-60, -48, -36, -24, -14 VDC[/TD]
[TD="class: product_01"]Filament Voltage[/TD]
[TD="class: product_01"]6.3 VAC[/TD]
[TD="class: product_01"]Filament Current[/TD]
[TD="class: product_01"]6 Amps maximum filament current[/TD]
[TD="class: product_01"]Measurement Functions[/TD]
[TD="class: product_01"]Plate Current (Ip) Range: 0 to 120.0 mA DC, ± 1.5 %
Transconductance (Gm) Range: 0 to 19.99 millimhos,
± 1.5 %[/TD]
[TD="class: product_01"]Test Frequency[/TD]
[TD="class: product_01"]1 KHz[/TD]
[TD="class: product_01"]Short Circuit test[/TD]
[TD="class: product_01"]Any inter-electrode shorts up to lK Ohm, Indicated by LEDs[/TD]
[TD="class: product_01"]Protection[/TD]
[TD="class: product_01"]"Smart Fuse" high-speed current limiter, AGC 1 Amp mains fuse[/TD]
[TD="class: product_01"]AC input[/TD]
[TD="class: product_01"]120 VAC, 75 watts max. input power (100, 240VAC models available)[/TD]
[TD="class: product_01"]Dimensions[/TD]
[TD="class: product_01"]8.5" D x 12.5" W x 2.5" H[/TD]
[TD="class: product_01"]Weight[/TD]
[TD="class: product_01"]11 lbs[/TD]
[/TD]
[h=1]About[/h]
USD $2,675.00
Click here to order.
  • Tests hundreds of popular audio, guitar amp, organ and radio tubes
  • Optimized to precisely test audiophile-grade tubes
  • Tests tubes at real-world power levels, up to 500V @ 160mA
  • Direct digital readout of true Mutual Conductance using a 1 kHz AC signal
  • Measures Heater-to-Cathode Leakage, Emission and Gas
  • Emission and GM results in percent-of-spec, and actual mA, mA/V, etc.
  • Listen to tubes for microphonics with the built-in headphone amplifier
  • Tests multi-section tubes, diodes, rectifiers and electron ray indicators
  • Fully regulated power supplies - no mains/line compensation needed
  • Fully protected against overload, shorts and overheating
  • Routine calibration is not required
  • Heater/filament power from 1.0 to 12.6V, up to 3.5A
  • User-programmable tube test data, stored in EEPROM
  • Processor-controlled tube pin selection. No switches, no rewiring.
  • Available for worldwide operation at 115 or 230V, 50/60 Hz (nominal)
  • Portable, compact carrying case, 18.5 lbs (8.4 kg) net wt.
  • Rugged, industrial-quality construction
  • Connects to a Personal Computer using a standard USB port
  • Free TubeTest© Computer Test and Curve Plot Software included
  • Print test data with optional Brother P-touch Label Printer
  • Free Tubedata Editor software, to modify test parameters and add tubes
  • Software requires a PC computer running Windows 98, XP, Vista or Win7
  • Designed and manufactured in the USA
Some tubes require an optional adapter for testing: List of available test socket adapters and socket savers.
[h=1]About[/h]
USD $2,675.00
That's the one right there, I was looking at that too, but the price...yikes!!
Guess if you plan on running lots of tube gear , it's justified.
I don't think he want's to buy a tester, he just want them tested.
I know. I'm hoping that if someone has a tester, they will volunteer their time to test his tubes. The first one at c. $600 might be worth owning if you have enough gear to justify it.
Yes, it would be nice if someone can volunteer however, I myself is considering the $600 tube tester. Where can I buy one?
I don't know what the MA2275 costs, but if it's $6000, then the $600 tube tester is only 10% of the integrated's cost and would be well worth owning to keep that or future tube components in top shape.
You're right. There are lots of testers on eBay for much less money.
Here is a nice EICO unit....pretty damn good since it has been refurbed and calibrated. NEVER buy one where the guy says his uncle was a tube nut and passed away, blah blah...generally these units are not working, they bought it and trying to pass it on..But if you can find someone local it would be better...and cheaper...LOL..call some electronics shops...sometimes they still have the testers around...
