Two questions here:
1) is it possible to wire CJ amps in triode? The answer is yes.
2) Will CJ perform this for you? The answer is I have no idea.
Sorry mep, not quite right. It is pins 3 and 4, but it is called the screen grid. Just "grid" usually means control grid which is the tubes input (pin 5). I mention this, because incorrect wiring will result in fireworks.
The 100 ohm resistor you mention goes between the plate and screen, not to ground. It's there to limit current to the screen which is far more delicate than the plate.
Pin numbers are for kt88, el34 etc.
I've yet to hear a pentode based amplifier sound better run in triode. Last cj amplifier I remember that was convertible was the Prem. 8. Think that says a lot. If it was better, cj would offer it.You just sacrifice way too running in triode.
You give up power and some control/punch in the bass typically. You normally lose about 1/2 of your pentode output power. Some people love the sweetness of the triode sound and are willing to sacrifice the bass punch and extra power to gain that sweetness. Not so good for rock, but some jazz people and chamber music people think it's the bomb. Some amps give you a switch so you can listen in either mode vice having it hardwired in.
Agreed but it's sweet because the upper octaves are rolled off. Plus it's kinda boring. Now not saying triode amps are bad but there's something about 6550s run in triode. You want a triode? Give me a 211 based amplifier.![]()
Cary makes one that you can switch between 211 and 845 tubes. The CAD805SE.Isn't the Cary Mike was talking about recently 211 based?)
Hi Myles
Any recommendations for a 211 amp? Thanks.
BTW, assume the reason more designers don't use 211s is the 1400 V.
Update:
Conrad Johnson will wire an ARTsa in triode mode and substitute the KT120 for Mullard EL34's.
That could be fun!
