Hegel H300 Review
Audioshark
Staff member
Sarasota, FL
The H300 (MSRP: $5500) is a nice size and weight for a ballsy integrated putting out 250 watts per channel. It won't win any beauty contests with its commercial look, but there is a beauty in its plainness. I would much rather see companies put more emphasis into sonics than looks....but I am a sucker for a good looking product too. The Hegel is plain, unassuming, but well built.
The H300 includes a full DAC section with a multitude of inputs. There is some confusion as to whether the USB supports the full 24/192, but it at least handles 24/96. It does not support DSD. Those interested in the capabilities of the built in DAC can peruse a multitude of online reviews of the H300.
I have no reason to doubt the claimed wattage, in my testing, it had plenty of drive and control, except at the most insanely loud levels. Pushed beyond 75% of the amps output things could become slightly compressed and quite emphasized in the bass. But at normal to loud listening levels (measured at 96db from one meter and 91db at listening position), this wonderful integrated is all a piece. Controlled, musical and delivering all the audiophile goodies: depth of soundstage, a wonderful tonality and a bass that is fast, controlled and extremely detailed.
The remote is solid metal and is very appropriate for this level of product. It provides all the necessary functionality a remote should. It won't kill a small pet or break a toe if dropped like my D'Agostino remote, but it won't break if you sit on it like the Rowland remote.
Listening to the H300 reveals an integrated that oozes musicality. The richness of an acoustic guitar or oboe in the orchestra is downright delicious. You can actually smell the strings on the guitar. If the designer was striving for tonality and musicality, he hit it out of the park with the H300.
The top end definitely does not lack for any additional detail. There is no artificial roll off of the top end. Stevie's harmonica at the beginning of For Once In My Life, Frank Sinatra/Gladys Night and Stevie Wonder - Sinatra Duets, Redbook had a wonderful crispness and air with no sense of shrill.
Soundstage depth is another real strong point of the H300. Listening to Oscar Peterson, We Get Requests, Quiet Nights and Quiet Stars on DSD, there is a clear separation of instruments with a wonderful sense of depth with the stand up bass in the back right corner, oscar at the piano in the middle and percussion on the front left.
The midrange is full with a hint of warmth. I found that vocals took on a wider soundstage presence than with any of the other amps I have tried on my Raidho D3's (D'Agostino, Rowland CS2). Whether this is a characteristic you prefer in an amp is up to the individual. I'm trying to refrain from comparisons to the Rowland, but I will say that the Rowland has laser like precision vocals which ultimately creates more space around the instruments and vocals. The Hegel vocals will likely more appeal to those who are fans of tube sound.
Complaints? Well, the lower mid bass can cloud the vocals - slightly - when the amp is pushed hard at louder than normal listening levels. Listening to Mark Knopfler sing the Dylan Classic, Restless Fairwell (Redbook from Chimes of Freedom CD) you can hear the bass lines cloud/muddy his voice a little. The Rowland CS2 on the other hand never did this and remained a champion of balance from top to bottom. But, the Rowland CS2 runs out of gas on the Raidho's when pushed hard and produces a slight shrill sound at very high volumes. A result of Class D or the SMPS? Who knows? The Rowland also doesn't have the tonality richness or soundstage depth of the H300 and the Rowland does not have the realistic bass that the H300 produces. But the Rowland is a champion of balance and neutrality, with laser like precision of instruments and vocals that portray themselves in a life like size, rather than a larger than life size. Pick your poison.
Matching this amp with speakers will generally be quite easy. I can see this integrated amp pairing with a lot of different speakers. With the Raidho's, I felt the bass from the Hegel could become a bit much at louder than normal levels. Below 95db from 1 meter, everything remained fairly balanced.
The H300 has a nice hint of warmth without being syrupy. The speed of this integrated, combined with its tonality richness, bass detail and high frequency sparkle ensure it is a great all rounder - especially at this price. Give it a listen....you may just find yourself getting Hegelized.
In conclusion, no Hegelian dialectic?
Thesis <>Antithesis----> Synthesis?
I actually quite like the looks. There is elegance in simplicity.
What is the DAC used?
Mike,
Excellent review! Since Raidho speakers are well known to be bass heavy in their presentation (starting from their monitors to the floor standers), has it been your experience that an amplifier that does not accentuate bass is a better match for Raidho speakers?
Thanks,
Anshul
Mike,
Thanks,
Anshul
Thank you and yes, Anshul, I would agree. The Raidho's, in my opinion, do best with an amp that is extremely well balanced from top to bottom. Fat bottom amps are not going to be the best fit. The Hegel is not "fat bottom" - it's well balanced, it is just when you push it beyond its comfortable limits it tends to accentuate and really drive the bass. The bass becomes a little more boomy and looses some of that balance. I forgot to mention in my review that at higher volumes (above 95db), this little sucker also gets hot. At moderate levels, it doesn't get overly warm and at idle, it runs barely warm to the touch. The Hegel is very well balanced up to about 95db (@ 1 meter) in my experience on the D3's specifically. When you push it beyond that, it tends to accentuate the bass. In contrast, the Rowland CS2 and D'Agostino Momentum Monos do not do this on the D3's. I'm quite surprised at how well balanced the big D'Ago monos are. But the D'Ag's re for my Alexia's and I'm a little uneasy shall we say with those beauties on the floor with my kids running around. I could just see a spilled cup of milk going down the top of them. OMG....just the thought makes me ill. So, the D'Ags are back upstairs behind a locked door! :)
I would bet the Hegel H300 on some 90db efficient speakers and above would be just the ticket. At the end of the day, in a field of over bloated, over priced gear, this is a screaming good value at $5500.
From TAS:
"The 32-bit DAC stage is built around the AKM AK4399 chipset. For Hegel it’s AKM’s best pro audio chip and capable of 24-bit/192kHz resolution. For USB throughput, resolution tops out at 24-bit/96kHz, but extends to 192kHz through either the optical or coaxial SPDIF inputs. Hegel notes that the new DAC improves over the HD11 with more robust and cleaner power supplies and newly designed, higher-precision clocking. Like the HD11 it features proprietary reclocking circuitry and a Hegel designed clock."
http://www.theabsolutesound.com/articles/hegel-h300-integrated-amplifier/
Mike, I finally read the whole thing and I agree it was a crisp and clear review. Kudos.
Mike is becoming one of my favorite professional audio reviewers. ...And I'm serious. :)
By the way, no one gave it to me for free, I'm not buying it (at least I don't think so), no one paid me to do the little review and Hegel doesn't advertise on Audioshark. And, I pointed out the good and the slightly less than good (there really isn't anything "bad"). Hopefully that's bias free. :)
At the end of the day, for $5500 MSRP, I can't think of another integrated I would buy. It has power, musicality, features, a built in DAC, a great remote, etc. Hard to beat to be honest with you. It's not perfect, no product is. But damn....it's really musical and enjoyable.
Up next...I want to try the Devialet (round 2) and I'm trying to get my hands on a Vitus RI-100 to try.
The Devialet D500's should be in mikes room by next Wednesday. I'm going to bring in a T+A integrated soon. If the sound is anything like the build quality, it should be amazing.
Good job Mike. Thanks for writing th review. Enjoyed reading it. The guys at Goodwins are big fans of the Hegel. As you say, they think it's a lot of bang for the money and very good all-rounder. Big taste of the high-end on a beer budget (well still a lot of dosh for most people but I guess it's all relative).
Exciting on both accounts. Every male audiophile likes T+A. ;)
Thanks Cyril. I like your analogy. Spot on.
Hegel H300 Review => Musical
Natural. Not artificial or contrived in any way.
That fits my description of the word as well (musical). ...Relaxed, smooth, pleasant, neutral, not emphasizing any particular frequencies of the full audio spectrum, not fatiguing/irritating even after long sessions of music listening.
* I asked humorously because in the reviewing audio world, "Musical" has various meanings for different reviewers and readers.
Plus, some people (very few though) consider that word "abstract", and simply prefer not utilizing it when describing an audio component or a pair of speakers. ...Kal Rubinson, I believe among the very few. ...But Kal's background is also in neurology.
I respect both sides; and I can relate to them both. ...That's all. :)
Great review. I have not heard that H300 yet but did hear the H80 in a few different systems at the Montreal audio show. For a $2k integrated the H80 was amazing value. Hearing that made me wonder what the H300 is like. Enjoyed reading this - good job.
