Yo hey!
For over a week searching the web for an answer ...
I was wondering ...
Just for a quick example:
When I create some stereo .mp3 with 320kb/s constant rate, does that mean each channel is playing with 320kb/s or these 320kb/s are divided into two channels with 160kb/s and when the file was recorded it was recorded with 160kb/s per channel, and when listening the song you actualy listening 160kb/s per channel?
The thing i care more is i have bunch of old movies on bluray disks and my bluray reader is gona die soon, already started to be hard for some disks to read, so i want to rip them into .mkv and put them on my hdd.
So most of the movies are in 5.1 48KHz audio channels.
I dont care SO much for the audio quality but atleast I want the quality of the audio track to be the same as if you listening high quality .mp3 file with 320kb/s 48KHz.
Because this quality is more than enought for me and i'm ok with that, but the audio channels of the movie will stay in original as it is 5.1 or 7.1 etc...
So if i rip the movie in AAC audio format with 5.1 48KHz 320kb/s, does that mean all 5.1 channels are playing with 320kb/s or these 320kb/s are divided in 6, and for each channel i have 53,33kb/s per channel, which is terrible ...
I want the quality of high quality .mp3 to be the audio quality in the ripped movie.
I have .mp3 with 320kb/s constant 44.1KHz which is 100Mb in size and the music lenght is 44min.
One movie was also 44min ripped with AAC 320kb/s constant 5.1 48KHz and the audio stream size was 102Mb.
And thats what make me think about bitrate per channel, because it just cant be the same size for stereo and 5.1 channels.
Does AAC has SO much better compress capabilities and makes the stream size pretty much the same as mp3?
I'm sorry if im not into the right place, delete it or move it if needed.
Thanks for the time.
I was wondering ...
