M
It seems to be more like the filter built into the TotalDac cable.
On other forums it has been touted as a "cheaper" Regen, both less expensive and not quite as good.
This thing works. I hear a more analog like sound, meaning less digital and noise floor is quieter. I do not like two of them as the sound becomes harder and more congested. I tried the earlier version of the Regen and did not like it at all. I have the new one coming in September. It's attached to my computer and my Aesthetix Pandora Reference Dac with the best Wireworld cable.:exciting:
Yash, be careful. When I tried to have people understand this, the poster who will not be named tried to belittle the comment. This despite the fact that he clearly did not grasp how async works., nor why Regen is a mini audio breakthru in an area NOBODY else was looking at. JS was motivated to address the (USB SI impact on noise propogation in the Dac) because of his high speed communications signalling background where optimized PDNs are a must and this is his forte. In bringing this to USB audio, he is finding rapid and tangible success.
To address a problem, you have to KNOW that there is a problem, or just be a beneficiary of blind luck.
As far as the John's design parameters go, where I question the regen's overall sound improvement limitations versus other more sophisticated approaches relates mainly to the clock. John has decided the best way to limit packet noise is to re-clock the entire stream at the signal interface using the regen's own independent clock. This step appears to be counter to the entire premise of asynchronous usb where the PC's (or server's) clock is rendered irrelevant and a much higher precision clock in the dac runs the show. Does the regen not work asynchronously with the dacs's clock which in most cases is vastly superior to whatever John has put in this $147 device? This appears to be the case and, if so, it would create an extreme limitation to the ultimate potential of the unit.
I have not seen this point addressed. If it has been I apologize; as has been made clear I am a slow learner. But if the unit is not using a full asynchronous connection, I would equate this design to cutting off your arm because your thumb hurts. Why sacrifice asynchronous jitter control and all its glory to manage packet noise???? Aren't there much better ways? If this is true, the unit would tend to only help dacs with average clocks being fed by sources on the noisy end of the range, but that's about it.
Paul,
Chillax. I was just poking you as you were doing to me then (3 whole days ago...how did you miss that!). No harm, no foul. I assume that got stale and we have undergone mean reversion.
(1) I said that no one else was looking at, so how do you turn that into no one else understands?
(2) In terms of credibility, who cares? I am not selling anything and like you I just share what I know and what I am allowed to.
(3) Not everything I am told can be repeated online, but all that informs my own world view. I take confidences quite seriously. If you told me stuff but aske me to keep it offline, I would!
Now, back to regularly scheduled programming. Did you check out the thread I told you about? LoL
So I tried putting the jitterbug in both usb ports of my Aries and heard an improvement each time. I know it sounds weird because I don't use a usb cable and therefore don't use any of the usb ports. The port intended for the usb cable had the most detail but could be a little on the thin side.
Do you mean RIGHT or write, here?Norman - "I am write and you are wrong."
Me - "What about these point that might refute your position."
Norman - "Well regardless, I am write and you are wrong but its a secret so I can't explain why."
Indeed!That was one of the most interesting things I have read about those devices, the idea that you could use them even if you aren't using a USB DAC.
Fun stuff and just shows how much we usually take for granted when just plugging things in.
EMC (Electromagnetic Compatibility) is a hard thing to achieve, and we usually don't even think of things like ground plane noise and AC-mains injected noise.
