Alkyogre
Introduction
Because at another topic there was a lot of confusion about howto install: here my guide how to install. To be honest the audiolinux site is very complicated with a lot of text etcetera, and sadly some installation lines even refer to old files which are changed to new names. With this I hope more people will be able to install this piece of software.
Materials and methods
- The audiolinux file. You can choose between headless and lxqt. I strongly recommend V3 headless. With headless you can scroll manually to a menu and download the protocols you want, for instance Roon, Audirvana, Jriver. After buying it takes some time before they will send it, but you will get the download file quick.
- Linux. Sorry to say this: but for audiolinux, you need another linux at another harddisc. An alternative is to burn a try-out linux on a USB-stick. I choose Ubuntu for this: you can download it here
Download Ubuntu Desktop | Download | Ubuntu
- After this download you can flash it to a bootable USB with balena etcher balenaEtcher - Flash OS images to SD cards & USB drives
- The USB disc could be used to try out Ubuntu and with that try out it is already possible to make the commands to burn audiolinux. I made a second boot harddisc
- An empty SSD which is hooked in your audiophile pc
After linux starts up, it is time to install audiolinux
- first of all: ubuntu does not have a root password yet. Open a terminal and type: sudo passwd Then choose a password and repeat it. If you restart this terminal type: su followed by the password to gain installation rights.
- next thing to do in the terminal is install gparted you need that for later: for that type: sudo apt-get install gparted
- download from the link in your e-mail the file you got from audiolinux. The download is stored in your Downloads folder
- in your terminal type: cd Downloads
- then type: ls (you will see the downloaded file, mine is called audiolinux_v3_531.img.gz
- then type: sha256sum audiolinux_v3_531.img.gz
now you need to verify the destination location from your empty SSD: to know this start gparted. type in your terminal: gparted
In the upper right corner you see a harddisc, you can click it and go to the other harddisc. Locations all start with /dev/ . Mine is called /dev/nvme0n1
- close gparted and go back to the terminal
- now type: gunzip -c audiolinux_v3_531.img.gz | sudo dd of=/dev/nvme0n1 bs=1M status=progress
last part of the installation is to expand the ext4 size. Without this: audiolinux cannot install anything.
go to the terminal and type: gparted
here: go to the right drive and resize the ext4 space, simply with the right mouseclick and after resizing save.
- shut down linux and remove the linux installation disc or installation USB. Select your new installed drive as boot drive in the bios and it starts
- After booting type menu and you see the menu where you can easily download a lot of audioprograms like Roon
Good luck.
Good luck.
