Amplifier for Dynaudio Emit M20 speakers
Leeds1967
Hello. Must buy me an amplifier that can drive Dynaudio Emit M20 speakers. Must connect a subwoofer and turntable. Have zero bearing then I ask you here for advice. Hoping for good answers so I get sound on the speakers. No surround amplifier.3333333333333333333333333333333333333.jpg
Effect (RMS)
150 W Frequency (max)
23,000 Hz Frequency (min)
50 Hz Sensitivity
86 dB Impedance
[FONT=&quot]4Ω[/FONT]
Welcome Leeds!
I enjoyed Dynaudio monitors (Focus 160) with a Naim Supernait2 integrated. That brand-to-brand synergy is well documented online, if you poke around.
The SN2 will give you a line level sub output but you would need to add a phonostage for your TT. Hope this helps.
...The Naim Uniti line will give you the same, plus a DAC and streaming capabilities, if that route intrigues you.
Your budget would help to narrow the field.
You can get a decent Cambridge Audio receiver with phono and DAC for $699.00
Hegel has a wide range of integrated amps with the goods to drive the Dyns but you'd need to add a phono stage.
The Parasound integrated is an option as well.
