Depends on how close you are to the amps, how quiet the room is, how loud the music is. The fan is not loud, but can be audible.
Has anyone ever tried a Pass Labs XP-30 Preamplifier with the Soulution 501 Mono Amplifiers and if so, how did it sound?
Never tried but with a 2k input impedance. I suggest sticking with the Soulution preamp that has an extremely low output impedance of only 10 ohms to match. I think the XP30 is at least 10 times that.
Just looked at your equipment list, I should have said stick with your lovely 100.8's.
Soulution should really be looked at as a system (pre and power together IMHO)
Hi Mark,
The Pass XP-30 output impedance is 120 ohms. The input impedance on the Soulution 501 is 2,000 ohms. That's 17x higher, isn't that sufficient?
Thanks,
Ken
Hi Mark,
Thanks,
Ken
Hi Mark,
Thanks,
Ken
Hi Mark,
Thanks,
Ken
I think may depend on where your final setup will be. If D3'are ever added to your system then Soulution all the way
Ken, just to let you know. I tried the Solution 710 with my Salon 2's, and it was not a good match. The newer Solution amps, like the 711, have a more natural sound. I still don't know if they will work with Salon 2's, but as David said, they're fantastic on Raidho speakers.
Here is a brief review I wrote on the Soulution 501 mono amps:
Right now, I'm running from the Esoteric K-01 directly to the Soulution 501 amps and then to the Salon 2's. Even without the 520 preamp, the sound quality is outstanding. There is tremendous clarity and purity of timbres, and distortion is virtually undetectable. There is also a high degree of resolution but it is delivered with a certain sense of ease, regardless of the volume level. Speed, dynamics and bass control are incredible. Drum strikes on some of my most dynamic Telarc recordings are lightning fast and impactful. Consequently, it just sounds a lot more like live music than what I've previously experienced. Overall the sonic signature is very neutral with just a touch of sweetness in the midrange and treble. I also had the opportunity to audition the Soulution 520 preamp and adding this component in the chain materially increases smoothness, texture and musical density.
Ken
